Results 1 to 10 of 10
Thread: (E16SE) Coolant Wire??
    Senior User matt_vaughan's Avatar
    Nov 2007
    Bradford, UK
    2,392
    Default (E16SE) Coolant Wire??
    I've got a spare wire from my coolant temperature sender in the end of the head, its a blue one with a spade connector on the end. Where does it go?
    Senior User Mike's Avatar
    Mar 2004
    26,594
    IIRC theres a sensor on the block (?) on E16's that it clips onto.
    Senior User Spudly's Avatar
    Mar 2005
    Hull, East Yorkshire. Drives: Vectra V6 'rusty bus'
    26,069
    1 Post(s)
    Isnt it in the same place on the cam end of the block that all small blocks keep it, im sure it goes onto a sensor/stud on there
    Mar 2004
    26,594
    Quote Originally Posted by Spudly View Post
    Ahh yeah yeah yeah, under the dizzy isnt it??
    Nov 2007
    Bradford, UK
    2,392
    that sensor is plugged in. but i cant see a spade that the blue wire with the spade goes onto?
    Also, I've got a black 2 pin plug too which I cant find the recipient for? It comes out from between injector 2 and 3.
    Mar 2004
    26,594
    Quote Originally Posted by matt_vaughan View Post
    Noo, the spade connector clips onto a brass nipple (like on an SR inlet manifold).
    Black plug between injector loom could be EGR?
    Been about 3 years since I last had an E16 motor so its all abit vaug :S
    Mar 2005
    26,069
    1 Post(s)
    Quote Originally Posted by Mike View Post
    Ummm, Moike, the dizzy is usually kept on the opposite end of the block to the cam end (although i meant cam belt end but wasnt very clear )
    And iirc E16SE is GTE engine and therefore no egr
    Mar 2004
    26,594
    Cant remember they do have EGR though, both of mine did as I removed them from the inlet manifold.
    Mar 2005
    26,069
    1 Post(s)
    Really, thats something i didnt know, i was always led to believe that it was the later 'eco' engines that used egr setup?
  10. #10
    Mar 2004
    26,594
    Thinking about it, I dont even think on an E16 there electronic actually :S really cannot remember?!
