anyone know?
anyone know?
well I've got 2 15's and 2 amps in the back of my 3 door nova, and there's not even enough space for a condom raper! ::
so one 15 will fit in nicely!
Have fun mate!
jus bought a alpine sws-1041 10" sub!!!
any good?
what music do you listen to?
is it in a box yet?
if so is the box ported or sealed?
An Alpine SWS-1041 subs are very good. Kevlar mix cone, dual nomex progressive spiders, santoprene edge...the only downside is that it needs a biggish box (1cu ft)
They are designed to give a boost of sound at 50Hz in the right box. You need a 1cu ft sealed box to do this. This is their optimum size. Amps with a bass eq have a setting at 50 hz, so will be a perfect match.
If you dont have an amp already, try the new Alpine MRP-M350 mono class D amp. 200W RMS@4ohms, it may be a bit too powerful though, so go easy with the settings.
WELL some did their homework didn't they!!! ::
cough *geek*
only jokin!
well obvisously this is the guy you need to speak to :wink:
i got a 15 in my boot in a sealed box also got the amp in there. mine is a kicker comp wi a legacy amp
Is that something that rapes condoms or did you mean a wrapper?? ::Originally Posted by wrigleys
yeh thats what I meant :oops:
yes..
