Following the 1300 engine failure , I installed an x14xe on the rally car of my children NOVA 1.3 sr . I've fixed a Plenum Mantzel, there are no power steering no brakes assistance(pedal box) and no VSS.
The probe AGR is connected but blanked.
I have the ECU and the transponder chip key correspondents and all the motor wiring.
I did not receive the connector of the transponder.
On the connector of the transponder that I found the color code does not match:
1 brown/purple
2 red/blue
3 -----
4 brown
5 black
6 brown white
7 brown purple
8 -----
9 red
I've connected
2 and 7 together to ECU red and blue
9 to ECU red +12v after my circuit breaker
4 ground
5 +12v after my ignition switch
The fuel pump is not running and I have no ignition.
I have a switch for the ignition coil +12 v after the circuit breaker.
I have a switch for the fuel pump +12 v after the circuit breaker if i can run the pump directly by this switch (not from the relay of the ecu)
What should we do with "ignition live " and "ECU light"?
On the motor wiring after agr connector, there is a case with a large red wire and a big black marker 70 what is it??
Need for help next rally last week
Thanks
