Results 1 to 4 of 4
Thread: flushed tailgate
    Senior Member
    Feb 2001
    4,624
    Default flushed tailgate
    Which do ye reckon is best,filling and smoothing the centre piece or putting a big panel right across the tailgate? if the big panel is better do you weld it on or will fibreglass do?
    Senior Member
    Feb 2001
    4,624
    Default RE: flushed tailgate
    filling and smoothing, if done properly by a professional, and respraying the whole tailgate should look acceptable... but, if you put the bit panel of stainless across the back, you dont have any chance of it cracking, or falling out when you slam the boot. It also reduces the chance of rust, cos stainless wont rust. Another advantage is that the change in angle of the tailgate means its almost impossible to notice the join, cos the light shines differently on the two angles, its kinda hard to explain, but trust me! Plus there is a lot less sanding to do cos you only need a bead of filler run along the edges to blend the metal in
    Senior Member
    Feb 2001
    4,624
    my mate had her tailgate flushed and i can assure u to get a plate welded and then smoothed over with filla hers was done all over wiv filla by a "professional" and it looks a bastard!
    Senior Member
    Feb 2001
    4,624
    tell u what im gonna do the whole panell in the next month coz my mate done his by filling the recess and under certain street lights it looks crap.
