It runs tried bigger main jets and it went better, but still not right, so then stuck the orininal 2mm jets in it and it now runs well enough to drive. it's no doubt bore washing it, but its a start. going to try and limp it to Tom Reid on monday and let him work his magic
aye, I think its much more in keeping with the look i'm going forOriginally Posted by Curtoise
ah right, thanks, i'll get a new cap and arm sorted just in case
The carbs don't seem to like running with the mechanical pump, as no matter what pressure I set the regulator at, it either floods at idle, or runs lean at full throttle. the bike pump solves this as it has a high flow rate with a low pressure, and can cut out when the float bowls are full.Originally Posted by zeifer33
