I am doing this mod on my Nova, when i bought the car it was a bare shell with no pedals. im stuck now of mounting the Brake Pedal, Clutch Pedal and Accelerator Pedal.
Anyone got any pics of this Mod, or info to help me complete it
floor mounted pedal box FTW
If i had the cash i would but not got the fundsOriginally Posted by Stuart
Check out my track day nova wip around page 30 ish
I couldnt find it on your thread mateOriginally Posted by Count Vaux Alot
im doin this soon too! just brought the corsa servo and revelant items!!
Still cant find it mateOriginally Posted by Count Vaux Alot
Ive taken this directly from the wip thread - its all there still so i dont know why you cant find it???
After finally getting my hands on a Corsa B brake pedal set up on saturday (thanks AW06!) i could get on with fitting it, so here goes....
We started with this - the raw ingredients
Then moved on the the car and the area of metal to be removed (Another note to myself just in case i forgot - luckily the only bit of rot on the bulk head was in this area!)
Out it comes
I then measured up and cut out a new piece of 3mm steel to fit the hole, resulting in a nice clean flat surface to mount the bias pedal box on
And i tacked it in
Once i was happy i welded the bad boy all the way round
Cleaned it all up
And stitched the front seam
Once the new metal was in place i got on with fitting the pedal unit its self (as im going for an adjustable bias pedal box see below i don't need the servo or MC)
I know i've replaced the above shelf with new thicker metal but, i don't think this is support enough for the brake pedal given all the support brakets i took out from the origional set up.
This added to the fact that i have hurd people with the corsa B set up complain that the bulk head flexes as you depress the pedal. This got me thinking what can i use to add extra support - i came up with this...
I modified the original bracket to suit the corsa pedal, drilled a hole in the corsa pedal box and fitted the nova clutch arm (i modded it to fit properly later on in the fettling)
This was the moc up fit just taked in place
It looks like this from the other side and out of the car
As you van see on the back of the pedal box i welded in a small rectangle of 5mm plate to add support to the bracket and give a decent mounting point for the pedal
Then it was latte time again mmmmmmm
As i said before the nova clutch pedal was just temporarily positioned until i got the bracket right, so once i had finished the bracket on the brake pedal i went on to make sure the clutch arm support was secure.
If you look at the picture below the bar to the corsa pedal from the clutch arm (the bit the clutch arm pivots on) doesn't sit flush up against the corsa pedal box, it sits at an angle this means you can't tighten it up properly.
So to cure this i removed the original fitting from the nova with a hole saw and did the same with the corsa pedal so it would accept the original nova one giving a flat surface for the pivot bar to tighten up to as so
Welded it in
And neatened it up
Jobs a good un!
This also brought the nut and washer on the inside of the corsa pedal away from the moving parts on the inside (the piston to the bias pedal box)
And there is more....fecking 15 pic cr@p!!
