Originally a 1.2 base model - this SR rep has been converted using all the right bits...
GENUINE 55k miles (all MOTs and FSH) the clocks have been chaned at some point - but its easy to work it out from the MOTs.
6 months MOT
No Tax
Full snow plough front bumper with all clips etc (no tow eye cover),
Full vinyl set
Full recaro burberry interior in near perfect condition
The shell is in awesome condition, no rust in the boot at all or on the rear chassis rail or front panel and engine bay seams or battery tray.
Had a tiny patch behind the n/s strut top - and thats it!
The bodywork is also pretty good - all original GM panels apart from the rear arch that has been fitted but not painted. Front wing has also been painted at some point and is a slightly different shade
The engine has been fully rebuilt, with shells, rings, stem seals, decked block, skimmed head etc, water pump, gaskets and belts all done too and runs amazingly as you would expect. As you can see from the pics it hasnt done hardly any work since the rebuild - 800 miles ish...
Rest is as you see it really, SR dials, SR steering wheel, Lxi 14" alloys, lowered 35mm and has a stainless Piper exhaust.
256mm 16v front brakes with new Greenstuff pads
Things that need doing:
Fill and paint rear arch
Tidy up front wing
Some dings around the body - nothing major
Some bubbles on bottom of front wing and arch and bottom of sill where it meets arch
The black 'stripe' on the engine bay seal is just underseal - not welding!
£450
Will be going on Ebay at some point next week - so be quick!
