cars looking good mate the dash looks minted
powered by 1.2
I love this car, great work so far!
Thanks for the comments
Been a long while since last update mainly because I've been busy but also havnt been in png much because I hate the new website, if it ain't broke dont fix it!
So here goes with a big update......
New wings, unfortunately there copy's but better than rusty ones!
Wings filled and set up for primer
Once primed I stone chipped the insides and round the arch edge
Then painted before fitted
Finally got the panel beater to weld the drivers door up
Coolant pipes fitted and pressure tested to make sure there is no leaks
Brushed some waxoyl on the usual rot place before fitting the battery tray
Made fuel lines and fitted pump and filter using a make shift ramp didn't get any pics of the work but will post some up once it's on a proper ramp up at my work
Engine bay finished off and had her running for the first time after alot of hassle with having no fuel or spark, turned out in the end vauxhall had sent me the wrong fuel injection relay. Useless fcuks. Runs well
Fixed the correct relay neatly on a radiator bracket
Pic of the spark plug cover before it got a lick of paint
Car getting trailered up to work to get painted
looking good bud. im in the middle of restoring my nova it at the same stage as you. seing yours is giving me the kick up the **** i need!
great work as usual :D Nice to see a door being repaired rather than just replaced (properly repaired aswell)
I think this is going to be something special when its finished, it looks really nicely put together so far, very clean.
looking good mate
Door primed and fitted with the other door along with wings and bonnet to make sure it all lined up before painted
Spot welded side skirt nipples on to the wings
Bonnet was just slightly touching the engine so had two slots chopped out and knocked in then welded back up. Then smoothed it off with filler and re-primed. Looks alot neater than just chopping a bit out, need some pictures of it finished.
Car an bits in the spray booth ready to be painted
