Page 7 of 7 FirstFirst ... 567
Results 61 to 65 of 65
Thread: *HOW TO* remove inner wings
  1. #61
    Club Member Club Member bazil's Avatar
    May 2009
    renfrewshire
    10,167
    Iirc I bent it as it was not the best, I'll check tho,
    success is only limited by a weak mind
  2. #62
    Senior User Club Member Novasport's Avatar
    Jan 2004
    Derby, Derbyshire. Drives: Nova Sport, BMW M3, Nova Swing, Peugeot 208
    9,086
    There is a 28k 5 door at the scrappy, might go and cut the one out of that
  3. #63
    Sep 2008
    Bridgwater
    12,248
    You bought that GSI then Rich ?
  4. #64
    May 2009
    renfrewshire
    10,167
    Rear chassis leg N/S
    so these legs have been cut from a crashed SR but can be removed from a complete car in the same process.
    here we have the leg already removed
    this would be the under arch view, notice how with the use of heat and wire brush the sealer has been easily removed
    here is the bootfloor area followed by rear seat area and footwell
    this would be the hardest area to get to, im my pictures it is the inner sill you see but to get to that you would have to remove a large section of the lower quarter panel to gain access
    and a few randoms of the removal and the seperated leg
  5. #65
    May 2009
    renfrewshire
    10,167
    O/S rear chassis leg
    here be the other side done the same way
    ideal if like me you need rear legs, both these will be cleaned up and used on my GSI.
