Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 42
Thread: not starting first time xe
  1. #11
    Jun 2006
    Cheadle, stoke-on-trent.
    14,968
    was it a 1.0 originally?
  2. #12
    May 2008
    plymouth
    1,872
    no from cold browney
    it starts but hesitates at 1st and flicks like its got an earth fault. but there all fine
  3. #13
    Senior User djbrowney's Avatar
    Apr 2005
    kings lynn
    4,334
    You checked the earth on the fuel rail, does sound like a crank sensor fault aswel
    There piss cheap on ebay now
  4. #14
    May 2008
    plymouth
    1,872
    yeh i have an earth going from the alt bracket to fuel rail, the one on left hand side of fuel rail attached. then the 2 on the right hand side.
    also one on the box to the chassis leg.
  5. #15
    User richi's Avatar
    May 2006
    Rochdale
    781
    Quote Originally Posted by John H
    yes was a 1.0 will it most likely be the crank sensor than? where abouts is it and how do i change it thanks alot for the help
  6. #16
    May 2008
    plymouth
    1,872
    open the bonnet facing the car, bottom left hand side of the engine. just under the thermostat ish
    held on by 1 x 8mm bolt iirc
  7. #17
    User richi's Avatar
    May 2006
    Rochdale
    781
    thanking you
  8. #18
    Nov 2008
    Chester, Cheshire, United Kingdom
    7,282
    Quote Originally Posted by richi
    Where have you got your switched live from?
    As the switched live for the coil, is around 6/8v on a 1.0
    Try running a wire to the + switched, from the purple on the wiper motor. This is a switched 12v supply.
    Same as the reverse light, but has a bigger feeder wire
  9. #19
    Banned
    Jan 2006
    Hull, drives: The Wife's Celica, Fixes: Mates cars, Saves: for A16VTB
    11,720
    crank sensor is a 10mm btw bud...
  10. #20
    Jun 2006
    14,968
    make sure you haven't got the coil wired to the 1.0 coil feed, the 1.0 coil operates at a lower voltage. Ignore matt an put a proper switched feed in if that's the case.
