hi
just wondering where to start solving my starting problems, sometimes it will start first time others it will take 3-4 tries, where should i start to look thanks
hi
Plugs
leads
distributor
crank sensor
fuel?
Most liely ignition related or crank sensor. Try a new genuine rotor arm & see if you can flash up any fault codes. Crank sensor will be at fault if the engine isnt running however.
craig, mine was hesitating to start today. almost like a bad earth if you get me but there all fine.
what would cause this?
is there a way to test the ht leads as i dont really want to change them as they are colouredOriginally Posted by swedge
You could measure the resistance with a multimeter, most leads are about 1k Ohms.
Different readings for different lengths
sounds like a fault crank sensor to me
both of us browney?
was yours warm ???
