as above getting a good 16 spi engine very soon .Wanting to put all my mpi stuff of my e16 gte engine on to the spi block has anyone done this before want to make sure it will work before i part withe cash
in basic terms, the bottom ends should be identical, the pistons are the same, the bore & strokes are the same too. an e16se head is higher comp than the spi one, so needs fitting. the only issue i have is to do with the placement of the efi temp sender. the earlier e16se had it on the block, the later ones had it in the silly ally thing bolted to the back of the inlet manifold.
thanks thats what i want to here .my e16 inlet has the wee temp sensor bolted underneath
its the big one i'm on about that connects to the ecu for the cold start. the temp gauge one is also in the ally thingy
Head would need to be changed anyway due to the port shapes
and the extra compression ....Originally Posted by AW06
Yeah i know, but im just saying so the OP didnt try and skimp (not saying that he would but you know) and leave the head.
Pistons are differentOriginally Posted by mowgli
The CTS for the ecu is in the side of the cylinder head.
Old XE track car
adam, my big boring piston book has the same pistons in both, but different heads.... so whats the second temp sender all about then???
Which 2nd temp sender?
The one near the inlet? (For the dash gauge?)
The pistons are identical in terms of size, they have different cutouts in though, the spi ones give a slightly lower cr.
Ive seen both blocks in a scrappy
Old XE track car
