Page 3 of 3 FirstFirst 123
Results 21 to 29 of 29
Thread: Help with 16se
  1. #21
    Nov 2008
    Northfleet Kent
    775
    Quote Originally Posted by mowgli
    IT WENT FOR 20 SOMETHING QUID. i was looking at buying it
    nar it went for £2 something he got it here and we collected it as was local to us
    Engine still not running though.. which is a bugger....
  2. #22
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    OK. i'm assuming that, when you turn the key, so the red lights are showing, the pump kicks in for about a second. if so, then all is good.
    if not, then
    1. ecu could be fried
    2. the pump is not pumping.
    if the pump is making the noise then either
    1. there is no fuel
    2. the pump is connected to the wrong pipe
    3. the pressure pipe is plumbed into the wrong port on the fuel rail.
    if is is an spi tank assy, then we assume the pump has been replaced with one from an mpi astra mk3.
    if it is a gte type tank, then it is pretty much foolproof
    if it is a carb type tank, then it could easily be sucking air from the wrong pipe. its been done before.
    and also, i assume the battery is fully charged
  3. #23
    Nov 2008
    Northfleet Kent
    775
    its a spi tank with mpi pump, pipes are on right way. and battery is all good and we had a boost pack on it to.
  4. #24
    Club Member Club Member comptoncj's Avatar
    Jun 2007
    Biggleswade Builds: Flame red GSI
    1,828
    have you got a managment light? Checked all the earths on the engine? I would be tempted to take the pump out and run 12 volts to at and see if the pump fires up.
    H27 ODW nova GSI
    B333XYP nova hutchinsons cabriolet
  5. #25
    Apr 2002
    35,194
    Quote Originally Posted by *Adz*
    you aren't answering anyones questions................
    DOES THE BLOODY PUMP ACTUALLY RUN WHEN YOU TURN THE KEY?????
  6. #26
    Nov 2008
    Northfleet Kent
    775
    yes to the bloody question you can here it and it worked fine before when the car was running about 2 days before hand.
  7. #27
    Apr 2002
    35,194
    RIGHT, that means the ecu is ok, & the relay system is working & so it is either the pump that is shot, or there is something restricting the fuel flow, as in blocked filter, or no fuel.
    if you slacken off the pipe, is fuel gushing out with the pump running??
  8. #28
    User chrisnovaturbo's Avatar
    Jun 2006
    ashford, kent
    1,290
    ive spoke to him on the phone and he said there is fuel and spark but no injector pulse. i havnt seen the car myself.
  9. #29
    Nov 2008
    Northfleet Kent
    775
    Quote Originally Posted by chrisnovaturbo
    Luke just bought another engine now, shame, as we just done gaskets and belt etc on the engine.
