Page 1 of 6 123 ... LastLast
Results 1 to 10 of 55
Thread: no spark on the c20let
    CASH ON COLLECTION ONLY
    Oct 2008
    leighton buzzard, bedfordshire
    3,690
    Default no spark on the c20let
    just read that it could be the fuel pump realy
    iv had to bypass my relay as it isnt working properly
    could this be the reason why im getting no live to the coil..?
    if so anyone got a spare relay thats close and could drop it to me like now or tomorrow
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    It wont be effecting the coil.
    DOes the ecu light come on with ignition?
    Oct 2008
    3,690
    nope tried that a min ago its like there isnt a live to it
    i pulled the ign. live throught the loom and have put it to the one on the nova loom
    but nothing
    even swapped bulbs about
    i no the live on the nova is working as i put the pump to it and it buzzes away like it should
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    But is it staying live when you crank the engine?
    Oct 2008
    3,690
    cant hear the pump when its cranking over so cant say really
    do you think its the ign. live dieing once its cranking over..?
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Some ignition lives die when you crank.
    Where have you wired it to?
    Put a multimeter on it, or a bulb and see what happens when you crank.
    Oct 2008
    3,690
    done it to the bottom ignition live on the black box
    did it with the xe in my old nova
    may it be that.??
    can go change it if it is
    just want it to fire up so i can finish the rest of it off
    Banned let_nova's Avatar
    Mar 2007
    argyll---drives:see SIG----
    10,435
    you connected the switched live?
    Oct 2008
    3,690
    black wire over the gear box you mean..?
    i.e ignition live
    yes thats the one i pulled back through the loom and connected to the black box
  10. #10
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    That should be fine then.
    DOes it turn over fine? (nice and quick?)
