first of i will apologize this is going to be fairly wordy.
ok peeps there is a reason there has been no updates. unfortunately the new head gasket did not sort it out, and after a couple of weeks of driving it with it boiling up on nearly every journey i got fed up and decided to take it of the road so i could do the job properly.
when i told my brother i was taking it off the road he said i should try and do the modification that i'v been bin researching for the past couple of years.
so here is project 16v
went scrappy and got a 16v valve head and pistons from a y17dt engine and started the long and disgusting job of cleaning the head up, as you can see its bloody filthy.
here you can see the awful design of the standard inlet manifold.
for soom reason four of the inlet ports are blocked of almost completely, by a restrictor plate
here it is with the plate removed
here you can see the rather poor inlet port design
nothing a bit of grinding can't sort, didn't go to mad, just smoothed it out a bit
This was my next step. So glad you are trying it. Take it you are using the VE pump with the 16v injectors and pipes rather than the VR pump?
right now back to the cylinder block, i decided to have it skimmed. so i stripped and sent it of, turns out it was not flat but the bloke did a cracking job of skimming it. only problem is i didn't check the cylinder bores before sending it off, and they turned out to be so badly pitted that i had to scrap the block.
sorry no pics of the pitted cylinder bores, i was not in the mood for taking photo's when i found
instead of wasting time trying to find and remove another block, i had the nice chaps at the scrappy do it for me £150 later this is what i got.
complete engine with turbo, fuel pump and even the aircon pump, all lovely bits that i can sell on, as i won't be using them.
these make stripping engines very easy and quick
heres my stage 2 uprated clutch
old pump on new engine
bottom end in, i didn't use the oil filter/ oil cooler housing from the y17dt as it got in the way of the custom inlet manifold that i was making.
mocking up the turbo
heres that custom inlet that i was talking about
Awesome!
Yes your welcome
sweet as dude
