oh and to go on from there,
might have got this bit wrong so feel free to correct.
Assume a nova weighs 900KG and in the super imaginary worls its 50/50 balanced FR/LR so tis 225Kg on each corner.
You have amazing slicks on that have a mu of 0.9
Thats approx 200N of launch grip you have to play with
Going with a 195/45/15 tyre size and the 25mm shaft, putting 100NM down it will give you about 380NM at the point of contact for the tyre.
working backwards that means you can 'only' put about 50NM down the shaft to not break that static friction at launch... which relates to a 0.5degree twist in the shaft. Which lets face it, is nothing.
That could all be a load of toss though
note that in 1st gear you are most likely putting thousands of NM of torque due to the gearbox mutiplying the forces
