Page 2 of 8 FirstFirst 1234 ... LastLast
Results 11 to 20 of 78
Thread: Rear anti roll bar options
  1. #11
    Jan 2003
    SOMERSET
    19,510
    I actually liked the feel of my mk1 1.2L without the rear (or fr) ARB's.
  2. #12
    Club Member Club Member bazil's Avatar
    May 2009
    renfrewshire
    10,167
    I've got a astra gte arb on mine, but IMO not worth doing cos all it does is stop the beam twisting, as they are not fixed between the chassis and suspension the do not eliminate body roll
    success is only limited by a weak mind
  3. #13
    Apr 2006
    14,188
    I put a Saloon one on for piece of mind - Was the only one I could get from a scrappy at the time
    And I'll likely put a thicker GTE/GSi item in the Mk1 back beam as well
  4. #14
    Apr 2006
    14,188
    Edit - Double post!
  5. #15
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Corsa is alot wider, i tried to fit a whiteline rear one (for a corsa) on to mine.. Was no chance. Am gonna try a cav one..
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  6. #16
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    ARB is well worth doing IMO. The rear beams DO flex a lot.
    Body roll isnt killed no, but in thery it helps, That is more down to the soft springs though. Hence track people run very very stiff rear springs.
  7. #17
    Club Member Club Member brucer's Avatar
    Apr 2007
    Old Radnor, Powys
    2,803
    Quote Originally Posted by AW06
    DaveB has a Cav one on his Corsa, If you can measure a Nova rear beam, it might work. Cav ARB is 120cm.
    Pics of his, Hope he dont mind
    this looks a good idea, but theres got to be a better way of securing the middle of it. maybe weld a flat plate across the middle of the beam so the bush can sit on, have the plate protruding out of the beam about an inch and then use some proper ARB clamps to bolt that to the beam. if anybody understands that.
  8. #18
    Jan 2008
    In Space, Lost.
    11,566
    Yeah, dave himself said it needs doing proper. Im going to do the same mod and plan to use the same exhaust clamps but also use a proper ARB U shape thingy.
  9. #19
    Banned
    Apr 2008
    suffolk
    6,797
    when i fitted my rear one i loved it,
    deffo felt the improvment
  10. #20
    May 2009
    renfrewshire
    10,167
    Christ I can't even remember how mine looks I know it is double bolted at each end but is not fixed in the middle, don't think the astra had it fixed in the centre either.
