Page 1 of 6 123 ... LastLast
Results 1 to 10 of 60
Thread: XE non start...
    Senior User Spudly's Avatar
    Mar 2005
    Hull, East Yorkshire. Drives: Vectra V6 'rusty bus'
    26,069
    1 Post(s)
    Default XE non start...
    Right guys got an interesting one to run by you all..
    Did an engine swap with my mate this weekend just gone, xev out of a vectra supertourer and inserted an xe.
    Now all the mechanical stuffs are done and dusted, we have the relay all plugged in and all the wires identified and sorted using the xev plug.
    We have one odd twin core wire coming out of the fuel rail that doesnt appear to go to anywhere as its snapped off, now were not sure what that is but thats not the main concern, it will fire over but there is no spark and no fuel at the rail.
    Live wire to the fuel pump and we get fuel but still no spark, we have had suggested crank sensor as a probable culprit, but what im needing to know is, will a crank sensor stop the fuel and spark if its not working?
    If anyone fancies having a nosey at the swap and what we got up to, there on vvoc is here.
    Cheers for any help and advice peeps
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Yes it will stop fuel and spark.
    The two wires you describe as broken sound like the ecu earths that bolt onto the rail, which would explain it not running!!!
    Mar 2005
    26,069
    1 Post(s)
    Quote Originally Posted by Adam
    Its one single black wire with two cores in it, my mates tested them and theyre +ve though
    Banned
    Jan 2006
    Hull, drives: The Wife's Celica, Fixes: Mates cars, Saves: for A16VTB
    11,720
    sounds ike your missing a permanent or switched feed to the ecu. if you put a 12v feed to pin 18 does it make a difference?. if you find a pic of the ecu connector i can tell you which other wires power it up.
    Mar 2005
    26,069
    1 Post(s)
    Ecu feed is there as we had it to the wrong terminal on the battery originally
    Ecu light comes on with the dash lights now so we know thats working
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Do you know where the wire is coming from?
    What loom is it? Does it have a engine to car loom plug in the engine bay, or is it in the footwell???
    Feb 2007
    16,486
    monumental link failure
    Mar 2005
    26,069
    1 Post(s)
    Not too sure what the loom is from, calibra dispack iirc, the wire comes out of the fuel rail wiring near the left hand side as you look at the engine, link works andy??
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Sounds like the ecu ignition live to me! Thats right where mine comes out, by the dispak
  10. #10
    Mar 2005
    26,069
    1 Post(s)
    Its at the left side of the fuel rail though adam, cambelt end, ecu should be working as the telltale comes on with ignition?
