You sure it needs a standard RS232 cable?
Nope im not sure
Theres nothing in the manual/wiring diagrams about having a "special" cable like MBEs etc use.....
Old XE track car
Hmm odd, nothing in the manual. I would bet it's not standard, though without any info
I PM'd Linch on here though as hes got the same ecu, and sure he said standard cable works on his. Maybe the cable is faulty, unlikely though IMO
Old XE track car
Yes just found some info that said it's a standard cable. Not great that it's not mentioned anywhere on their site.
I agree, cable fault unlikely. Where the batteries you tried known good? I.e fresh off a car that's used? Only thing it leaves is faulty ECU, again unlikely or the PC.
I've just installed the software to have a nosey and it's trying to connect to the serial port at 192000kbps not 9600.
Another aftermarket ECU with VB6 software - fairly robust COM stuff though so you shouldn't have too much bother assuming no faults.
Well ive never used the serial port on my laptop but theres no reason why it wont be working.
Yeah i tried the speed at 192000 (it flashes up when you first start the software/try to connect to the ecu)
The battery is a bit old, but was showing over 12v. Might hook it up to the nova battery and see if that gives any joy, but it aint looking good.
Old XE track car
visual basic 6? ugh
i got my mbe cable today so ill have serial cable laptop frollics tommorow myself
"let me drive.. i won't make a fool out of you"
have fun!
Adam: You could try using Hyper terminal (as the laptop has a serial port I'm guessing it's fairly old so running XP at the latest?). Set the port etc and connect and try issuing AT as a command and see if you get a response. Will confirm connectivity or not.
Failing that post up pics of your com port configs (from device manager etc).
How do i go about using HT???
Yeah its running XP Pro SP2. Going try the ecu on the nova battery in a bit, will post back.
Old XE track car
