Results 1 to 8 of 8
Thread: MK2 Dash in a MK1 + Digi Clocks
    User de-slotted's Avatar
    Nov 2009
    Staffordshire
    133
    Default MK2 Dash in a MK1 + Digi Clocks
    I am thinking of swapping my MK1 Dash & fittimg MK2 Dash,so i can fit digi dash in.Is the wiring the same? & can it be done ?
    Nov 2003
    Austin, Tx, Usa
    24,200
    dont be gay
    Jan 2003
    SOMERSET
    19,510
    Yes & Yes.
    Nov 2009
    Staffordshire
    133
    Quote Originally Posted by craig green
    Yes & Yes.
    Thanx so no mods then?
    Nov 2009
    Staffordshire
    133
    Quote Originally Posted by General Baxter
    dont be gay
    I arn't
    Jan 2003
    SOMERSET
    19,510
    Quote Originally Posted by de-slotted
    depend how you class a mod, its a mod fitting a mk2 dash & a mod fitting a digi dash.
    All the info you need is probably in the articles/tech guides or in the archives of the advanced search function.
    Feb 2010
    Droylsden, Manchester
    154
    so everything is in the tech guide?
    Banned
    Apr 2008
    suffolk
    6,797
    you will need all the plugs from the mk2 dash. with some wire on each.
    then the wiring will be straight matches on every plug. if i were you, i would do the dash first, then do the digi at a later point .
