ive got a kicker comp sub and its got 2 positive conections and 2 negative am i ment to wire up to them all of them or just a chosen 2
all of them, depends what ohms each coil is and what ohms your amp will run at will determine if you need to run in series or parallel
Dual voice coil, if you want to google it.
sounds complicated
Not really. I assume you have a manual for it (if not, whats the model - manufacturer website may have manuals online)? Should explain it all in there, and more importantly give you the resistance loadings and power ratings dependent on the connection configuration.
"It'll be done when its done"
you can do it as your wireing up two subs + - + - or wire it on one channel just dubble the wires from the amp .or you can do what i do.. put a wire from the - to the + (on the sub) then your two wires from the amp to the other + and _ on the sub and you would just wire a normal sub.and this will give you the full power of the subwoofer
just watched a few videos on you tube and i think i understand now
