Results 1 to 6 of 6
Thread: Engine switch, reverse??
    User General Lee's Avatar
    Feb 2008
    Bracknell Berkshire Drives: Nova 01
    1,206
    Default Engine switch, reverse??
    Hi
    I have just swapped my 1.2 carb 4 speed engine for a 1.4sr 5 speed, i have connected up the alternator and starter fine no problem, im having trouble connecting up some wires, i have 2 wires a positive and (a negaitive i presume), which came off of a switch which is located just below the clutch arm. Is this the reverse light switch, if so thats fine, because i have a euro light, therefor no reverse light.
    Also is the oil pressure switch meant to have 2 pins comming out of it on a 1.4.
    One more question i am missing a metal spring clip that goes on the distibutor cap, it a about 3 inches long and clips the dizzy cap to the dizzy, im sure most of you know it. Where can i get one of these clips from?
    These are all my niggles with my engine swap. I hope!
    Thanks
    Aug 2003
    flint Nr Chester
    3,941
    yes its the reverse light, steal it of another dizzy or use a zip tie
    Feb 2008
    1,206
    Quote Originally Posted by Jon_nova1
    Cool thanks, No need to connect that up then.
    I don't steal. Never though of using one of them. I was going to make one but the steel need to be pretty springy.
    Also the oil pressure switch pins? is there meant to be 2
    Nov 2003
    Austin, Tx, Usa
    24,200
    Quote Originally Posted by Black Stig
    theres a two pin and a single pin
    single pin is just for the light on the dash
    the other pin will be for the gauge in gsi/gte clocks
    Moderator burgo's Avatar
    Apr 2003
    kettering
    22,773
    11 Post(s)
    just rob the oil pressure switch off the 1.2
    Feb 2008
    1,206
    Quote Originally Posted by burgo
    Would it be a straight fit?
