Page 1 of 2 12 LastLast
Results 1 to 10 of 15
Thread: Digi Dash speed?
    Apr 2009
    118
    Default Digi Dash speed?
    Just fitted a digi dash in the nova, went for a spin and the speedo reads about double what it should be, ie when im doing 50mph its about 120mph. Any ideas? Could the signal wire be broken somewhere? cheers
    Apr 2006
    14,188
    Try the red switch on the top of the dash - It has 2 settings
    Flick it the opposite way to what it is and it might solve your problem
    Senior User Club Member
    Apr 2008
    Coventry
    11,892
    Quote Originally Posted by vaughanmc
    nope as at 50mph it'd read 80kph, unless he thinks he was doing 50 and was actually doing 75
    Apr 2006
    14,188
    It'll either be the red switch or a dodgey transducer ?
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    Quote Originally Posted by MK999
    Your thinking the MPH/KPH switch, which is on the trip reset.
    Not the red switch as said, Red switch changes between the two transducers that astra's came with.
    Apr 2008
    Coventry
    11,892
    ahh ok, only ever noticed the one switch on them myself!
    Apr 2009
    118
    No, it switches between mph and kph fine, they both read double what im actually doing. As there is two type of transducers, AK and AH, Ive got the AK transducer. So ill try the AH transducer.
    Jan 2008
    In Space, Lost.
    11,566
    The red switch changes between the two transducers.
    MPH/KPH is changed my the trip reset pin thing.
    Jul 2008
    Unknown
    9,635
    the red switch is behind where the top screw mount is at the circuit board.
  10. #10
    Apr 2009
    118
    ive moved the switch but it makes no difference
