Hi everyone, I'm having a few starting issues latley, When I go to start the car it turns over slowly like the battery is flat. It does start and when it does the it runs ok, I have checked the battery connections and the negative connection is cracked, I used a voltmeter and without it running I get 12.83v and with it running I get 13.9v so I assume it's charging.
It has a digital dash and a 2.5v6 engine so I pressume it has the 2.5 loom?
Last night after work I went to start it and nothing happened, I put the key in turned it and nothing at all. tried to turn the lights on and nothing???
After wiggling some wires at the back of the dash god knows what it seemed to light up then I turned the key and started it up.
I have noticed that when I put the indicators on the dash seems flash in sync with them.
Anyone have any ideas?
I think its dash related I hope
Thanks in advance
