my clocks are loose and im trying to get them out to replace them with a digi dash how do i get it out with out ruining them? iv looked through the guides but cant find anything. thanks
i thought the cowling around the steering coloum had to come off before they came out. dont quote me on that though as im not a mk1 nova owner
iv removed that but still cant seem to get it out ???
thanks
ah ok then mate, im out of ideas now good luck anyways!
mk1.
the whole dash has to come out im sure,
mk2 top cowling comes off.
on the mk1 they prise out front the bottom edge etc but be gentle and the speedo cable will be holding it back so go under the bonnet and push it into the car so you can get your hand in to unclip it.
and the digi needs a bit cutting to make it fit the mk1 dash :D
if you undo the speedo cable from the g/box its alot easierOriginally Posted by brainsnova
that would be sooo hard to get at it from the glove box. Just get on your back put your arm up in there detachs the 12 pin from the back of the dash same as the speedo and then prise it out by making it go bottom end up then wiggle it out till it comes! try not to damage the contact film on the back of it!
