Results 1 to 6 of 6
Thread: Alternator/battery light on/fuses blowing
    Newbie
    Dec 2009
    Wakefield,West Yorkshire
    3
    Default Alternator/battery light on/fuses blowing
    Hi all i have a 1992 1.2 nova saloon been having problems with alternator been told alternator from early corsa is the same is this correct?
    Borrowed one and fitted it, seems to be working and shows charging on meter. when key in ignition there are no ignition lights. but when started and give abit of gass battery light comes on, yet when i check battery reading shows charging. Also seem to be blowing fuses continuosly especially the one that controls fuel gage, temp gage and reverse lights.
    HELP????????????
    Aug 2004
    Ipswich
    941
    welcome how are you checking the battery for charge buddy?
    Jan 2009
    durham
    114
    would be checking for a ignition live and putting multi meter across battery when engine is switched off should read around 12.8 volts. start the engine and when charging it should read around 14.4 volts iirc. lower than 13.8 volts would be suspected alternator.
    Senior User Club Member
    Nov 2005
    Inverness
    2,670
    My mates Nova had this problem, it was an earth, are your indicators etc all working OK?
    Newbie
    Dec 2009
    3
    thanks all
    sorted problem now was a short circuit from new cd player (which dad fitted ) earthed to wrong wire derr !!
    Newbie
    Dec 2009
    3
    and also bad earth too the fuse box
