Results 1 to 8 of 8
Thread: Switches
    Oct 2008
    Sussex, Newhaven
    584
    Default Switches
    Hi all, Is it posible to wire up the hazard switch and the blower switch to toggle switches on a mk2? For the blower i will only need one speed. Say the middle speed. If so how do i go about it?
    Cheers dave
    Senior User mowgli's Avatar
    Apr 2002
    35,194
    i think the hazard does too many processes & i'm not sure about the legalities of a toggle switch to operate it...
    the blower switch would be easy, disconnect the loom & splice in 2 wires for the feed & speed
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    A toggle switch should be fine in terms of the legality, MOT etc. Its just the headache of wiring one in, iirc the Mk2 hazard switch has all sorts of silly connections
    Senior User Club Member
    Apr 2008
    Coventry
    11,892
    Quote Originally Posted by Jack
    It's a 4x3 connector iirc, of which only about 3 slots aren't used, so crack out the wiring diagrams if you want a toggle on that
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Can't be too hard
    Apr 2008
    Coventry
    11,892
    6 pole double throw toggle switch, sorted
    User 16xe_chris's Avatar
    Feb 2009
    West Yorkshire
    1,141
    Quote Originally Posted by novanova636
    Cheers dave
    I have a 3 way switch for my blowers, i pulled off the plug on the back of your standard switch cut all the wires off, i first tested which one was the feed, i put that to the middle of my new switch and then speed one to the top and speed 3 to the bottom of the switch
    Hope this helps matey
    Oct 2008
    Sussex, Newhaven
    584
    Cheers guys. I hues just chop it off and give it ago really
