Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Someone fit my digi dash !!!
  1. #11
    Senior User Club Member
    Nov 2006
    Sunderland
    4,821
    Ok well ill have to plug those back in and try it out, will my earth on the chassis leg have to be moved to earth on the back of the clocks then ?
    +REP BraninsNova for the advice so far
  2. #12
    Jul 2008
    Unknown
    9,635
    its easier and neater to join them all at the clocks inc the transducer wires.
  3. #13
    Nov 2006
    Sunderland
    4,821
    Ok ill have a mess around with it tomorow and see what happens, thanks for the advice so far mate.
  4. #14
    Banned
    Apr 2008
    suffolk
    6,797
    what aw06 done when he installed mine, was splice the digi plug on the loom, keeping the old plug. if i ever wanted to get rid of the digi.
    and im sure as yours is a mk1, there are some differences.
    pm him :D
  5. #15
    User w_wall_2001's Avatar
    Oct 2004
    sunderland
    364
    did you get sorted with the digis? if not ill have a pop pver and have a look if you like?
  6. #16
    Jan 2007
    The Netherlands
    3,381
    if the indicator lights are on contstant (so not flashing like they should) you have an earth problem.. constant indicator lights is a + over the earth..
  7. #17
    Senior User mowgli's Avatar
    35,194
    lewi. the digi dash should be a pretty much straight swap with the wire to the gearbox as an extra...
    so you should be able to pick up everything off the haynes wiring diagrams
