Page 3 of 7 FirstFirst 12345 ... LastLast
Results 21 to 30 of 61
Thread: heated screen
  1. #21
    North Events Co-ordinator Moderator boffer8's Avatar
    Feb 2006
    leeds
    1,336
    3 Post(s)
    why not just wire into the circuit of the rear screen?
    If Carlsberg did Motor clubs, then IDMC would probably be the best motor club in the world.
  2. #22
    Nov 2008
    Chester, Cheshire, United Kingdom
    7,282
    Quote Originally Posted by boffer8
    will be pulling too much current fella!
  3. #23
    Senior User sparkie1401's Avatar
    Sep 2008
    Town
    2,852
    as Benn said
    im doing it that way aswell
    and yes too much current if used on same switch as rear window, windscreen man told me that slso
  4. #24
    Senior User Mark's Avatar
    Jul 2003
    Bristol
    7,443
    Quote Originally Posted by sparkie1401
    What about if you don't have a heated rear screen, do you reakon it would be ok then?
  5. #25
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Quote Originally Posted by MattBrown
    You use relays. a, for the timing, b, to keep the heat out of the dash, and c, as you can use a tiny switch in the dash, no a hoofing big thing.
    Oh really?
    I KNOW that on some Fords with heated windscreens, they are run through TWO 30amp fuses.... (one per side of the screen)
    I have no Haynes here but can someone have a look what fuse protects the rear window heater circuit? Id be very suprised if it was less than 30A!
    Oh and Landrover heated screen kits come with a 70amp relay Ok, it aint a nova but that gives you some idea of the amount of power they use
  6. #26
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    I'll go with Ad on this...
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  7. #27
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Heated FW uses a LOT of power. I know this. I have one. My revs - on the V6 - drop when I turn it on.
    Mine had two heated tracks on it, four wires coming off. I think we wired in two relays for each track, but from the same switch. Its a big light up one on the dash so I won't forget to turn it off
  8. #28
    P N G Adam's Avatar
    Nov 2003
    Stoke-on-Trent
    30,497
    Yep they usually do have two circuits(one per half of the window)
  9. #29
    Sep 2008
    Town
    2,852
    Quote Originally Posted by Mark_UK
    then should be fine as it one switch for one window
    but its a "ON/OFF" switch so u need to rememeber to turn her off
  10. #30
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Quote Originally Posted by Razorjack
    Mine does that when the fans come on.
    Far from suicidal
