Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: car over heating
    Oct 2009
    Northern Ireland
    339
    Default car over heating
    88 hatch 1.2 ... overheating ... steam pours out off the front grill its not leaking that i can see ... a slight build up off hard cheese on the expansion bottle cap
    any help advice..
    Aug 2003
    flint Nr Chester
    3,941
    head gasket
    Oct 2009
    Northern Ireland
    339
    are you sure ???theres no creamy stuff on the rocker cover cap ..
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    It depends if the head gasket has gone on the water ways which would give cheesey deposits on the header or if the oil ways go then the cheese is usually on the oil cap.
    Aug 2003
    flint Nr Chester
    3,941
    well for overheating the only real causes are
    water pump
    thermostat
    fan not working
    ignition too far retarded/advanced
    not enough water
    head gasket
    theres not really alot to go wrong with the 1.2
    Oct 2009
    Northern Ireland
    339
    ohh ok ... ill be getting a new gasket next week then as the head is gettin skimmed.. culd any1 tell me how you know if the timing belt is about to go ???
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Just change it when you do the head gasket.
    Just a thought when did you last flush out the water system. If you've got steam coming from the grill then the radiator may have a small hole in it from all the water pipes being blocked.
    Oct 2009
    Northern Ireland
    339
    ive only owned the car a few weeks so never :L
    Sep 2008
    West Yorkshire lad
    22,243
    6 Post(s)
    1 Thread(s)
    Give it a flush out first then before changing the gasket. It may just have a load of dirt a rust in the system. If it starts doing it again and the pipes go rock hard then it could well be on it's way out. Double check that the radiator has no leaks though.
  10. #10
    Club Member Club Member brucer's Avatar
    Apr 2007
    Old Radnor, Powys
    2,803
    out of the grill? be a leaking radiator, drop an egg in there.......
    dont let it over heat too often as it may warp the head/block. you could get the cooling system pressure tested for leaks at a garage or seal the expansion bottle with your mouth and blow.pmsl.
