Page 1 of 2 12 LastLast
Results 1 to 10 of 13
Thread: x20xev problem
    Oct 2007
    England
    991
    Question x20xev problem
    hi , the engine management light came on, on my mk4 astra sri 2.0 16v (x20xev)
    diagnosed it and it said ,
    throttle position sensor low voltage.
    camshaft sensor incorrect signal.
    iv changed both of these sensors with brand new items and the fault is still there.
    its doin my head in as it has flat spots through the rev range and wont rev over 4500 rpm.
    using loads of fuel too.
    any suggestions??
    thanks.
    Club Member Club Member comptoncj's Avatar
    Jun 2007
    Biggleswade Builds: Flame red GSI
    1,828
    timing belt slack? also crank sensor could be faulty and causing the cam sensor and tps to get the wrong info,
    H27 ODW nova GSI
    B333XYP nova hutchinsons cabriolet
    Oct 2007
    England
    991
    Quote Originally Posted by comptoncj
    really think so??
    timing belt is fine.
    surely it would come up on diagnostics about the crank sensor?
    Oct 2007
    England
    991
    anyone?????????
    Jun 2007
    1,828
    the ecu only knows what its being fed from the sensors, its common on x20xevs to have a bit of slack in the belt and gives the cam sensor a false reading, you need to get the car on a machine with a graphing mode to diagnose the fault, im in the trade and do all the diagnostic stuff at my work and have come accross a few x20xevs with intermittent cam and crank sensor faults and one of the was a stretch timing belt, but obviously i havnt seen yours so you need someone in the know to investigate it a bit chap
    H27 ODW nova GSI
    Jan 2003
    SOMERSET
    19,510
    Your 1st mistake was taking the fault codes literally. The fault more than likely lies with the loom connecting said sensors.
    Oct 2007
    England
    991
    any ideas how i can fix the problem?
    Jun 2004
    Down Under
    2,241
    As said, the wiring for the cam and crank sensors on these is very guilty of failing. It becomes very brittle, and is the major failing point on these engines.
    Check all wiring to and from these sensors and id put money on it being damaged somwehere.
    Usually where it clips into the rocker cover (youll understand when you see it)
    Jun 2004
    Down Under
    2,241
    Use the images on this guide as an indoor help
    http://www.vauxhallownersnetwork.co....d.php?t=155691
  10. #10
    Oct 2007
    England
    991
    cheers, ill chck the wiring tomorrow.
