Ah ok, I had a 4 speed box on my 1.2 carb that I fitted by mistake once...
Originally Posted by MK999
its called lying...........or they sent a special one for official testing.......
to be fair my 1.2 expression did 98 on gps, will the f10 improve acceleration at all?
unless down an enormous hillOriginally Posted by brake-dust
I don't think it will actually even fit, cos the clutch, flywheel & bellhousing on an f10 installation is way smaller than an f16/20, so the starter won't line up, the input shaft is different, so won't fit into the flywheel, and then there is then problem of the extra torque simply knackering the gears & bearings.Originally Posted by brake-dust
A pal of mine had a corsa XE with a F13 box, it would just spin the wheels for fun, a total pig to drive!
the wheelspin & bad handling were nothing to do with gearbox choice, just idiot driving style.
f10 doesnt fit over the fly wheels any way! f20 it is then
Amen.Originally Posted by mowgli
Its power, got mine to hit an indicated 110 @ 4krpm iirc, so can shift quite a bit more!! As a guestimate using a 4-speed F10 you could expect about just over a ton
