!!! STUNNING!!!
BMW 7-SERIES
730i V8
Finished in ULTRA RARE Navarra Violet Metallic (The only one I can find in this colour in the UK!)
Additional Spec':
22" Dynamic design alloys with good tyres all round
Quad Exhaust System (Very expensive & makes the V8 sound even better! However, is quiet on the motorway)
Lowered on FK coilovers
Graduation tints (Gets darker more toward the rear of the car to keep the feds happy!)
Multi-Function ///M Steering wheel with all controls, including Cruise settings (From M5)
Specification:
This car is fitted with all the toys....
Full Black Leather
Electric Front seats with Memory (Even the headrests operate electrically!)
Electric Windows
Electric Sunroof
Electric Mirrors
Remote Central Locking (BMW Alarm & Immobilser)
Air-Con
Dual Climate Control
On-board Computer (OBC)
Cruise Control
Headlight Wash System
The car drives brilliantly, is nice & smooth plus has lots of power on tap. The 5-speed auto gearbox has an adaptive mode, which alters itself to how you drive in order to get the best economy. It also has 'Sport' mode, which improves perfromance & gives excellent response in 'Kick-Down'.
At night, the dash lights up like an aircraft! All lights work & there are NO missing pixels from any display. (This is a common problem with E38's)
MOT - November 2009
TAX - Argust 2009
Serivce History
The car comes with all its original documents including the BMW service booklet. It has 14 stamps, 8 of these being BMW Dealerships & the others largely stamped by "Autobarn - BMW Specialists and Rays Autos – BMW Specialist” if wanted I can give the days and mileage on what service was done on
Mileage is 141,000 & there are 1 green lights on the service indicator.
BAD BITS :o(
The only issue is the OBC needs replacing. I think it's called the 'Check-Control' unit, basically when you switch the car on it performs a load of checks. In this case, it says to check headlights, side lights etc...Etc... Then after a few seconds it goes away! It simply a small box that needs replacing under the steering wheel area. I've been informed these can be picked up from BMW for about £100. So not expensive if you want to fix this or needs a new Speedo cluster what can be bought form eBay for less than £50.
When the steering wheel was changed for the M5 item, the airbag light came on. It basically needs a reset. Any BMW specialist can turn it off for around £10. I just haven't got around to doing it.
The car is located in Swindon & can be viewed any time
Email me at stealthnova@hotmail.com or call me on 07525623360
£3500 ono
