Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 41
Thread: 5 Stud conversion?
  1. #21
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    Oh, then the cv will be small block.
    Dont know what the gear box in on one of them tho so cant say if its big or small block.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  2. #22
    Feb 2009
    doncaster
    3,159
    will update tomorrow but if people use nova gte shafts and big block inners why cant i use diesel shafts with big outers
  3. #23
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    They dont, they use cavmk2 inners, which have small block shafts but use a big block inner, so the cv has a big block end, but the inner bit has small block size and teeth/splines.
    You cant just put a big block cv on a gte shaft.
    Far from suicidal
  4. #24
    Feb 2009
    doncaster
    3,159
    tried today on the spare shafts the big outers DO NOT FIT ON DIESEL SHAFTS
  5. #25
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    I know. Derv shafts are still small block.
    Far from suicidal
  6. #26
    Feb 2009
    doncaster
    3,159
    yes benn wondering how david has sorted his, i have pm'd him so will add when i sort out what needs doing,
    loadsa help if your using big block but nobody seems to have covered 5 stud small blocking yet so hopefully it will help others out
  7. #27
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    I spend ages looking for the cv books at work trying to workthis out.
    As i wanted to use my gsi/gte shafts which have a 28spilne end and have a big block cv to run the 5stud.
    No big block outers that i could find thru the whole gm range have a 28spilne.
    Thats why i run safts that are big block both ends.
    Far from suicidal
  8. #28
    Feb 2009
    doncaster
    3,159
    that means i need to check up as corsa c cdti sris are 5 stud meaning i can use small block shafts still but buy new 5 stud hubs which will be a direct fit
  9. #29
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    1, is that engine a small block?
    2, its all about the spilens on the cvs, i'm sure i checked corsa c's cvs and they wernt the same.
    Far from suicidal
  10. #30
    Feb 2009
    doncaster
    3,159
    mine is a corsa c basically so should be ok will make a few calls monday
