haha hey , thts cheaper
Cheers peeps,
Cheers peeps,
Thats a min, it could be 300notes, but cvs say £30 2nd hand,+ hubs £40/50 +brakes (5stud ones cally or cav) £50-80 + rims £100-200 +rear set up £50-100.
Thats a rough work out..
ive just converted my x16xe corsa to 5 stud, everything went together really well but the main issue ive had was when it was built up the short pass shaft seemed to long so having to use a nova gsi shaft instead of the corsa one that was on it
davie
Thatsd cause corsa shafts are to long and wont fit...
cost me 30 for the front v6 brakes and hubs and a corsa hub and carrier to convert my 52 combo going to use the cally outer cvs on my dti shafts
also davie did the big cvs go straight onto the shafts mate as thats now my only issue
Bargain there.Originally Posted by davidfox280585
Big block cvs wont fit small block shafts aswell you can work out the right teething. Nova outers are 28teeth. I dont think any big block outers come in that (i have looked before)Originally Posted by davidfox280585
all from a local scrap yard from a vec v6 sri 288mm but i have some c20xe shafts spare i was going to try a outer cv on a spare 1.7 dti shaft i have i took the v6 hubs and have them to my friend with the corsa hub as corsa cs use same bearing dimensions as corsa bs and novas surprisingley gonna try tomorrow to fit the outers then go from there why has my van got small outers then being a 1.7 . . . Interested in seeing how davie has sorted his
If it a nova van? If not then no it will be big block. You didnt say what van it was.
combo 1.7 dti 2003 but use same hubs as corsa bs and novas
