Let me know asap please mate
Old XE track car
just notised its the banjo bolts i have
Thanks anyway
Old XE track car
adam av just checked the 2 sandwich plates i have and the one i removed from an xe engine wich is the one pictured on the left the diameter of the threads for banjo bolts is exactly 10mm. the larger of the sandwich plates wich came from a let engine has a thread diameter of 12mm, and yer i also have the bolt wich goes thruw the plate and into the block to screw filter on to.
do you still need rear door cards mate as ive got a mint rear set you can have foc and can bring to the national.
I think i have a fuse box cover aswell.
I will dig them out and bring to the national.
Gaz, i may be sorted now thank to Philip. Cheers for all your help anyway
+rep
Ernie, draper has some for me, but he aint going Nat day, so if your willing give me some foc and are going nat day that will be sound!
Cheers
I still need the mk1 ashtray and the middle heater duct Lads BTTT
Old XE track car
thats good adam , pleased you got it sorted in the end pal . and mine are still ther shud you need them just let me know.
i dropped them off at john hs for you adamOriginally Posted by Adam
wot havent you got yet mate?txt or call me on 07971388941
Mk1 Ashtray
Middle heater vent ducting
Mk1 Steering column shrouds(if there different to mk2 ones?)
Fusebox cover
Cheers Draper
Old XE track car
