You dont happen to have the bolt that holds it to the oil pump too do you?
Will check the number on epc later
Old XE track car
yer i have the bolt aswell mate.
Sweet, how much do you want???
Old XE track car
is it the right one adam? as i cud add pic for you? £10 posted ok?
ive got some rear cards adam, yours FOC if you want em pal
No results for that number mate, but 90322484 is the cally/cav sandwich plate, with banjo fittings, which isnt the one i need. I assume with the number being close thats the type youve got too.Originally Posted by gaznovalet
One i need is part number- 90194141
Draper-Going Nat day mate???
Old XE track car
here is the 2 sandwich plates ive got, the one on left is from an early xe and one on right is from a let.
no im not adam, however..............
i am going to meet john H at some point soon to pick a fuel tank up so....
providing its ok with him i could drop them off and then you can get them that way (somehow )
Thats sound Draper, I can just call round Johns sometime..... Cheers
Gaz, do you have any std oil cooler pipes that you can try on them?
The one i need has smaller threads than the later banjo type fittings.
Old XE track car
i dont adam i sold the oil cooler and pipes to my mate for his corsa, but i have got the blanking bolts wich fit that sandwich plate. . i cud measure the width of them threads if that wud be of any help to you?
