Page 3 of 5 FirstFirst 12345 LastLast
Results 21 to 30 of 44
Thread: Bleeding Water - C20XE Overheating
  1. #21
    Mar 2009
    540
    Quote Originally Posted by gaznovalet
    wen car is running does water circulate the whole system ? can tell by removing header tank cap and see if any water is coming back thruw the thin top water pipe and into the tank?
    I get water and occasional bubbles through the small pipe. Not sure if its pumping through all the time though
  2. #22
    Apr 2009
    529
    no gm thermostats dont have bleed screw just the aftermarket ones do, bubbles are sure sign of air in the system, wen you rev the engine or squeeze bottom water pipe the water shud flow back into header tank via the return pipe on top constantly, just out of curiosity wot level is the water to in your header tank and wen its been running if you remove header tank cap is it pressurised?
  3. #23
    Apr 2009
    529
    also you can bypass the heater matrix by simply joining the two water pipes together wich run into it to see if this is at fault.
  4. #24
    Mar 2009
    540
    Just tried it, it flows a fair bit when the car is revved etc.
    The car gets hot and still no fan or heat from heaters :S
  5. #25
    Mar 2009
    540
    Only tried running te car with the water in the header and the cap off... so im not sure i it does pressurise or not...
  6. #26
    Mar 2009
    540
    can you swap the heater matrix pipes around? as the one on the left (the awkward one out of the two) has two kinks in the pipe, and i would like to rule this out as being a problem... although it still seems like the thermostat is being the problem... cant see why as its a brand new one from halfrauds
  7. #27
    Apr 2009
    529
    yes you can swap the 2 pipes around as it dont matter wich way the water goes in or out the matrix. worth a try if you see kinks present as they certainly wont be helping.
  8. #28
    Mar 2004
    Fareham, Hampshire
    23,813
    12 Post(s)
    I have a gm hosing and it does have the bleed screw.
    Let the car warm up, take the cap off every so offen till all the air comes out. Then top all if/when needed. Only way i've ever done it.
    Far from suicidal
    Still I get them tendencies
    Bringing back them memories
  9. #29
    May 2006
    newport
    379
    ive been told that the fan wont cut into until the cap is screwed on water gets hotter under temprature and XE are self bleeding
  10. #30
    User ant_tay's Avatar
    Jul 2008
    Bridgend, South Wales
    1,199
    i knid of have this problem i have a digi dash and mine goes up 1 bluse section and 2 yellow and if it goes up to 3 yellow bits the fan kicks in but i also get only cold out of the middle vents
