Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: getting a nova on a JIG
    Oct 2003
    583
    Default getting a nova on a JIG
    is there still places that could put my nova on a JIG to check thats its still nova shaped. it pulls to the left still i thought it was doing this because the cross member had snapped and the tie bar fell off but even after new cross member and strengthening its still doing it
    can tracking cause pulling to the left
    Feb 2008
    Bracknell.
    4,609
    Quote Originally Posted by a2lt16v
    Yes
    Oct 2003
    583
    next question then does anyone run coil overs on there nova and it actually handles well mine seems to have so much camber im running on the side walls (well not quite but its too much)
    can anyone give me a measurement from the front arch to the middle of the wheel as a starter (3 door flat arch type)
    my front arch is below my tire tread
    Aug 2007
    Cumbria
    1,628
    Your running standard topmounts?
    Oct 2003
    583
    yeah standard top mounts i havent got round to getting those adjustable ones yet
    someone put me off saying that i have made the car stiff enough already with seam welding coil overs and poly bushes and if i put those top mounts in i will probably smash more than the cross member this time
    Aug 2007
    Cumbria
    1,628
    How will topmounts make it stiffer?
    And the seam welding allows the shell to take more stress not only make it stiffer.
    I'd invest in a set of eccentric topmounts and have your wheel allingment properly checked out/ set-up.
    Oct 2003
    583
    do the top mounts not have a bearing in or are they still rubber mounted
    i thought that they were solid ali with a bearing in them where as the standard ones have a bush in there
    do i want concentric or eccentric
    Aug 2007
    Cumbria
    1,628
    Hmm, that's the only thing I can think of that might make a difference.
    Not an expert on topmounts but I'd say eccentric ones are more suited for sorting out your camber issues.
    Oct 2003
    583
    maybe i should try some of them then
    its just it doesnt feel right kind of heavy on the steering but only in one direction. think its just going to be a process of elimination
  10. #10
    Banned
    Apr 2008
    suffolk
    6,797
    sounds stupid but tyre pressures all ok, if one was low and one high. might effect the handling?
