Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
Thread: Wiring up a car sound system at home
    Aug 2008
    Romford, Essex Drives: moredoor Loonage
    2,916
    Talking Wiring up a car sound system at home
    I feel like doing this i know it is possible, im pretty confident in doing it. But there's a few things im not sure about.
    If the head unit can be wired up and all working correctly, im good to go from there with wiring up speakers and amp etc.... now i know what all the wires do for the connections on the unit. Obviously, Live would wire straight to the live terminal on the battery, and earthing to the earth on the battery.
    1. what would i wire the ignition wire to, and the other wire that dims the display when the you turn the headlights on?
    2. What could i use to earth the battery out to? anything at all metal?
    Thanks for the help
    Senior User AlexW's Avatar
    Jan 2008
    In Space, Lost.
    11,566
    What are you going to use to power it?
    Jan 2008
    In Space, Lost.
    11,566
    But if you run it off a car battery you put the earths straight onto the battery, the earth strap from the battery to the metal is so it makes a circuit, if you earthed it onto a bit of metal it wouldnt make a circuit.
    Ign live you would have to put onto the positive on the batter, put it thought a switch though. Oh and fuse it all.
    Aug 2008
    2,916
    yeah i know that bit, the earth from head unit to battery earth, so just earth the battery to any metal surface yeah? ok cheers, and which wires do i fuse? The Permanent live, and what else?
    Jan 2008
    In Space, Lost.
    11,566
    wtf what did i just say. Dont earth the battery to anything! It wont work!
    Fuse both the lives. although your head unit prob has one on the back.
    Aug 2008
    2,916
    sorry didnt know what you meant, why wont it work if i earth the battery? so i just earth the head unit, but not to the battery
    Senior User Spudly's Avatar
    Mar 2005
    Hull, East Yorkshire. Drives: Vectra V6 'rusty bus'
    26,069
    1 Post(s)
    Are you fitting this in your home or your car?
    Jan 2005
    Hull
    2,990
    Did this eons ago (1997!) with kenwood krc-151 and a pair of 6.5"s.
    The earth from the head unit goes direct to the battery, that's it.
    main power and ign power go direct to the battery too, with a fuse in each one.
    Other than the speakers and an aerial, thats all the wiring needed.
    I'd recommend using a gel-type battery though, as the normal ones tend to give off harmfull fumes.
    Aug 2008
    2,916
    im fitting it in my home, and thanks mikey14sr. going to do it tomorrow, ill let you all know how it goes
  10. #10
    User novaxe235's Avatar
    Nov 2008
    bristol
    551
    have u got a scalextrics if you have dont use a battery use the power pack of the scalextrics there usually 240v in 12v out .much easier and better imo.
