yep.
yep.
sounds obvious, but does it have coolant in it??
Its not anything else but the imobliser. It wouldnt come up with the imobliser code otherwise!
It cuts out after running for 5 mins? Does it struggle to start after? Crank sensor perhaps?
5 secs. And as i posted before^^
ECU light flashes like mad which means imobliser fault
If the ecu was a non-immobilised one then surely it could not flash the ecu light, as it would not be programmed to do so...
The engine will start fine without a VSS signal
Old XE track car
Aye i know, CK was sure its non-imoblised though. I dont even know anyone with a baby xe that the ecu can be tested in
sounds to me like a component failure, maybe caused by bad wiring..
I'm tempted to at your arrogance when you were talking about the project first but na, I know the feeling only too well. You tried what RRV8 said? Can you take a look at what you've joined to what, make a note of it and possibly a few pics as well mate?
I spent 90% of my money on Drink and Women, the rest I just wasted.
Might be worth re-trying all your wiring. You seem very confident that it is the ecu but isnt this the 3rd ecu? Only so many times a workman can blame his tools.
Ive had it before and was absolute hell. Got it running eventually though
