Results 1 to 6 of 6
Thread: dual voice coil
    BASS JUNKIE
    Jul 2008
    christchurch
    747
    Default dual voice coil
    how do i wire a dual voice coil sub from the amp? do i need a special amp or just a nomal 2 channel one do? i know im useless with these things
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Amp and sub make/model?
    It all depends what resistance you want it to run at.
    BASS JUNKIE
    Jul 2008
    christchurch
    747
    kicker comp 15" sub, jbl 200 watt rms 2 channel amp temporary until i get a monoblock
    Mar 2004
    milton keynes
    488
    Humm interesting subject I've got a JL12w3 running it on just one coil at the mo (crap cheap amp).
    Single channel amp ie mono in think if I'm right you go from one side (one set of terminals) to positive then neg on other set of teminals could be well wrong tho???
    Mar 2009
    540
    use www.the12volt.com and it will tell you how to wire series and parallel to get the required load your looking for (Ohms). Just make sure your amp resistance is the same as the way you have wired your sub. For example a double 2ohm voice coiled sub can run as a 1 ohm load and a 4 ohm load, depending on how it is wired. The lower the load, the louder the bass, but the more current the amp will draw off the electrical system
    Mar 2004
    milton keynes
    488
    That sounds like spot on advice! Hay and what do you know I'm doing mine right woop!
