code 93 is the quad drive modual
the what
Nice one Baxter :D I live in Keighley. What's your prefered beverage
It must have been a different car I was thinking of then when resetting the ecu .
Just looked on topbuzz and your right but it has n/a after itOriginally Posted by burgo
apparently the duad drive modual controls a number of things and its usually one of these at fault and not the actual modual
quad drive module is part of the ecu. so if this is the only fault codes you are getting then more than likely u need a new ecu...
Earth problems can give quad module fault
Old XE track car
thinking about it actually, this is exactly the same symptoms BIGS had with his car and it was 100% the ecu. if i remember correctly his had the same fault code come up (as well as others but i knew about them )
ive been googling it and came up with possibles
egr valve
lambda sensor
knock sensor
engine management light bulb
earths
He hasn't got the egr valve anymore, put on a 4branch manifold, would this cause the problem
