Basically, I have gte clocks in my 1.0
The oil guage is constantly fully round, thus making me think theres no sensor, what can I do to sort this?
Matt
Matt
you need a 2 wire gte oil pressure switch. then you ll need to run a wire from the clocks to the pressure switch.
^ bingo
If its the gauge you'll need the sender not the switch tho.
If the wires unpluged then it will go off the top.
sorry i ment the sender theres no oil pressure switch
Yeah there is, its what most novas have, just turns the light on.
ok i fail.
Right, anyone got one of them??
So off a gte I need an oil pressure sender?
Yes.
I beileve they are all the same on vauxhall engines tho, so anything with a pressure gauge will work.
