Page 391 of 398 FirstFirst ... 291341381389390391392393 ... LastLast
Results 3,901 to 3,910 of 3973
  1. #3901
    2,618
    Revel in the subversion.
    All an arb does is (in part) add strength (you no longer need), unsprung weight (I expect you wouldn't like) & add effective spring rate (when it now can just be achieved through a change of springs should you even need it).
  2. #3902
    13,247
    I'd prefer to limit roll with a roll bar rather than increase spring rate. It'll keep the rear end safer on the straights, and a roll bar is a lot more tunable at track side for wet days - none, standard, 22mm and 25mm are all available and changed with 4 bolts.
  3. #3903
    2,618
    You'd be better off replacing the bushings for spherical bearings
  4. #3904
    User NOVANICK's Avatar
    Sep 2002
    swindon
    190
    Wow, great work. Read the whole of this thread from start over past week whilst travelling for work. Now motivated to get mine back on track as its not been touched in years... Thanks!
  5. #3905
    2,618
    Nick are you the guy that bought Nigels yellow atb / carbed / alpha ign nova like in your avatar?
  6. #3906
    13,247
    Quote Originally Posted by NOVANICK View Post
    Cheers mate, I luckily hosted my own images so the threads not too broken! Glad itís helped, see you on track this year.
  7. #3907
    Sep 2002
    swindon
    190
    Yes thats right. Still got it but runs on mbe mgmt and throttle bodies now.
  8. #3908
    Sep 2002
    swindon
    190
    Yes, the images were a blessing! indeed, see you on track!
  9. #3909
    23,768
    Sounds like you need a project thread!
  10. #3910
    13,247
    I've finished the toe-linked beam, fitted it and tested it. It was eventful, that's for sure.
    So I needed a roll bar on the new beam, so I fabricated some mounts out of 25mm box section with captive nuts to facilitate the fitting of a mk2 Astra GTE secondary ARB:
    Fits nice and snug:
    Handbrake guides also re-attached as my Corsa C rear discs use this:
    Old one removed, new one fitted:
    All fitted:
