Page 374 of 410 FirstFirst ... 274324364372373374375376384 ... LastLast
Results 3,731 to 3,740 of 4097
  1. #3731
    brotton , saltburn by the sea
    1,877
    Looks like it could have been expensive .
  2. #3732
    13,604
    Michelin S9C which are quite a hard compound. Second hand and easily sourced. They last quite a few track days
  3. #3733
    Oct 2010
    Hertfordshire
    236
    Thanks mate. I've found a few sets available second hand 👍
    When you guys next out?
  4. #3734
    13,604
    Hmm probably early next year no plans yet! Part of the fun is camping out the night before.
    Plenty available usually about 200 for four. They last me a good few track days
  5. #3735
    Junior User
    Sep 2012
    89
    Where do you get them from, Iain ?
  6. #3736
    13,604
    Just a few eBay sellers mate, no special contacts. Team up with a mate and get 8 to make it a bit cheaper. Some of them are a bit messy/peeled but scrub up fine with our use.
    They could probably really do with a 7J wheel (and arch work) but they do work on 6J.
  7. #3737
    Junior User
    Sep 2012
    89
    Awesome ! Thank you and good luck, will keep an eye on the progress (and use some of the ideas if you do not mind)
  8. #3738
    13,604
    Last outing at Donington I picked up a fibreglass bootlid, second hand but unused/boxed. Just finished fitting it over the past month or so.
    First off, it has captive nuts to bolt on original hinges, which Paul kindly let me relieve off a mk2 Astra bootlid which shares the same hinge mechanism:
    This resulted in a shocking panel gap
    Standard Nova car-side hinge got ground back, crushed in a vice and shaped to avoid the boot-side bolt heads:
    Boot inner skin got cut out for access and more weight saving:
    Aerocatches fitted (also a second hand bargain )
    These were modified so the pin could be mounted horizontally:
  9. #3739
    13,604
    Knocked up a professional spray booth My first attempt at gun painting, it's 2k primer, flatted then 3 coats of colour-matched 2k paint (my car is miles off the Glacier White it's supposed to be ):
    Inside pins are taken care of with two shaped pieces of 3mm metal, edges curved to stop the plate flexing:
    Also in the above pictures are a much smaller boot seal that was required as the gap between the boot and car is much less than the steel item.
    Finished product now with window fitted, Very happy with the paint considering it's my first DIY paint job. I think I'll re-apply the Sport-esque graphics I had on the last one:
  10. #3740
    Ash vale, Hampshire
    1,471
    Looks good, what sort of weight saving would you gain from this?
