Results 1 to 10 of 10
Thread: NOT STARTING (HELP)
    Senior Member
    Jul 2002
    glasgow
    315
    Default NOT STARTING (HELP)
    right started the girlfreinds car the other day when i was replacing the fuel pipes at the sender unit no problem(when using the battery out my car)so bought a new one for her a desil one for more power so went to start it to night and it not catching it's nearly there but it won't go the little extra to catch and run could this just be the cold?and the is also a noise coming from the sender unit when trying to turn the car over is this normal or is this another problem and mybe causing it not to start?
    Senior Member
    Oct 2002
    Fife Scotland Drives: Nova Luxe+ 1.4i
    164
    just to get this right, was it starting OK with your battery but not with the new battery you bought? and the car you are working on is a diesel?
    Senior Member
    Jun 2002
    milton keynes!!CARLTON CRAZY !!!!!DONT MESS
    1,394
    nope its a GTE,
    bump the fucker see if that works
    Senior Member
    Jul 2002
    glasgow
    315
    YES STARTED OK WITH MY BATTERY THEN I GOT A NEW BATTERY BUT WHEN I WAS PUTTING IT IN THERE WAS A BIG FREEZE WELL THE CAR WAS ALL FROSTED(VERY COLD) UP AND NOT STARTED FOR A COUPLE OF DAYS SO I GOT A DESIL BATTERY BRAND NEW FOR THE EXTRA CHARGE AND IT SOUNDS LIKE IT'S NEARLY STARTING WHEN PUMPING THE PEDAL BUT WON'T AND I CAR HEAR A KINDA BUZZING NOISE FROM THE SENDER UNIT AT THE BACK
    Senior Member
    Sep 2002
    Wulveramton Drives: 106 Diesel
    3,127
    I know you have to pressurise the system? But it will usualy start Ok, Try bumpin it.
    Senior Member
    Jan 1970
    Stoke-on-Trent
    3,883
    the buzzing noise isnt the sender it will be the pump, which gets much noisier when it has little/no fuel in it.
    are you sure there is petrol in it?
    get back to me if u have iliminated this as i have past experience with this engines
    Nov 1999
    West Midlands Drives: Work In Progress
    7,742
    snds like its trying but aint quite there.
    try bumping it if not its something mechanical or fuel related as said previous. id go with that too
    if its not trying to ignite, then maybe an iomobiliser fault, blown fuse or something ingnition related? just cos it cranks dont mean that theres a spark
    Senior Member
    Jan 1970
    Stoke-on-Trent
    3,883
    he said 'its almost there' which to me means it is trying to start and therefore a spark.
    so there isnt enough of a spark or at the wrong time, lack of compression, or lack of fuel, or blocked exhaust
    Member
    Oct 2002
    thurso,scotland
    76
    I had a prob like that before with my gte,the fuel pump was knackered.
    when i tried turning the car over i got a strange buzzing noise from the pump.
  10. #10
    Junior Member
    Sep 2002
    Dover
    14
    I had a problem with my gte not starting. :evil:
    after changing fuel pump, fuelrail and various other parts it turned out to be a duff dizzy, only sparking when it wanted (when I checked it had a spark but only on the one sylinder, the one I checked!) .
    might be worth a look. :idea:
