Page 8 of 10 FirstFirst ... 678910 LastLast
Results 71 to 80 of 100
Thread: Nova GTE - turbo
  1. #71
    Jan 2003
    Leamington Building V Quick & Low 17'd 8v GSiiiiiii And Driver of B@rge
    1,207
    Easy tigers!!!
    12PSi with Standard compression!!?! Brave man!
    I've had mine bored out to 1650cc and am using the metal head gasket spacer that Courtenay supply. Im just about to order two Competition head gaskets to put either side of the Spacer, ready for the DTA equipment to be added.
    At the moment Im running 10PSi with Water injection cutting in at 8PSi.
    The car runs lean off boost then rich on boost, which is a no win situtation as the only fuelling control at the moment is the Pressure regulator, which acts linear (ie. If I increase the fuel pressure it will make it rich low down as well as on boost).
    The rods are standard (Can you get different ones?)
    The Pistons are Standard over size ones (1650, as mentioned earlier)
    I've just took a ?2000 loan out to sort the engine good and proper! All the DTA stuff comes to about ?1500 then im having an Electronic boost controller fitted as well which is used on VeeDub Turbo Conversions as DTA don't make one suitable.
    Hopefully within the next few weeks i'll have one SORTED Engine. I just can't wait to see what it is like to drive and how much power it kicks out. I think im going for about 12, 13 maybe 14PSi as I've got to keep it sensible as im using the car every day.
    The Gearbox is an F13WR off a Corsa Diesel to help put the power on the road rather than up in tyre smoke. Im also using a Black diamond clutch.
    I don't think im going to attempt it all before PV2003 as I really want to take the car and not have it in a garage. So if you see me there, come and have a word and i'll tell you all the plans for it.
    Cheers
    Neil
  2. #72
    Sep 2002
    231
    Do a search for "Arrows Engineering" they make rods to order - they wont be very reasonably priced however..
    Interesting point though, what kills standard cast rods? Is it high RPM or boost?
  3. #73
    Member
    Oct 2001
    Bounds Green, London
    62
    Ben I was told that the standard cast rods will break at 15psi. I was also told that steel ones are available for these off the shelf. In our case boost kills the rods not high rpm( :?: )
    Matty
  4. #74
    Member
    Jun 2003
    eastbourne
    40
    ive ran mine at 17 psi before for a couple of months running it every day and i didnt have any problems! cant do it now though coz im only running one head gasket now.
  5. #75
    Jun 2002
    Cleveleys, Lancashire
    4,104
    im guessing its not so much boost - but the power being produced at those boost levels that shatters the rods
    ie tuning the engine naturally to the power levels of 15psi boost or using NOS to obtain those levels of power would also start chewing rods
  6. #76
    Sep 2002
    231
    I've got a N/A 16v lump and have been advised that the rods bend then crack at high rpm (greater than 8k sustained) - something along the lines of "high axial loading" which I presume means G ?!
    I'm guessing also then a steel crank would be advised also?? All pricey stuff
  7. #77
    Jan 2003
    1,207
    Hi Dav,
    Just a few questions for you.
    Why have you stopped running 17PSi?
    Why run with no spacerplate at 12PSi as its a lot safer with it? Is it just for more power?
    Do you know how much power it put out at 12 and 17PSi?
    Any other Internal work on your engine?
    I have ordered all the DTA gear, its coming a week Monday as the loom is being specially made. Im uprating the fuelling system to take 200bhp (just incase I get near that dizzy height) with 16V Injectors and a better fuel pump. Speaking of which can anyone recommend a good one? I would do the same as you Dav but those cars are a bit hard to come by in the breakers yards!
  8. #78
    Member
    Jun 2003
    eastbourne
    40
    Hi neil. ive stopped running it at 17 psi when i decided to run the car with only one gasket. The reason why i decided to do this was because i wanted to reduce lag and i could have the car just as quick running at 6 psi than at 17psi with 2 gaskets. it also meant that i didnt have to mess about with the fuelling to much because it is running lower boost. To give you an idea of how quick it is it sits with my mates brand new rs focus from stand to 150 mph on his clocks! the engine has been bored to 1650 with hepolite pistons, powerboost valve set at 3.5 bar, cossie sierra fuel pump, frontera intercooler, stainless steel boost pipes, T3 turbo and no thermostat. It all runs through an F16 gearbox from a '92 sri cavalier with a one off heavy duty clutch. Why dont you run your car on carbs with the turbo? I knew a bloke who used to run a gsi lump with a pair of 48 dellorto's with a group 'A T3 turbo off a cossie. this thing was seriously lethal. it would smoke the 17's in third in the dry!
  9. #79
    Member
    Oct 2001
    62
    Sorry to resurrect an old post but at what rpm are people generally boosting 8 or 9 psi? Also what quarter mile times do people get with 1.6 turbos?
    Matty
  10. #80
    Jan 2003
    1,207
    There isn't an answer for that, as Turbo's spin up at different rates depending how much work/load they're put under. In my car, if you put your foot down it can take 1...2...maybe three seconds before im at 9psi and going like a bat out of hell, it also depends what rpm you are originally doing before you floor it.
    Dav posted a time of 14.7 at PV2003 in his 1.6 Turbo
