all the ron plug does is earths a certain wire or not dependant on which way you turn it. on any vaux with one thats also got a knock sensor, i.e the xe, the sensing is done by the knock sensor, which advances or retards the timing, dependant upon knock, ie pre ignition. so the ron plug is redundant. hence why it runs without it. on spi's i.e 1.2's, the ron plug is there to deciefer between 91 ron (leaded) and 95(unleaded), a good trick is to find a 98 ron plug and fit that, as it advances the timing a bit more. put tescos 99 in and feel the difference.
