Results 1 to 5 of 5
Thread: Need Help!
    Mar 2005
    211
    Default Need Help!
    Hi just right now i have a 1.2 engine with 1.2 wiring. I have this speedo installed at the moment:
    which is working fine. I'm thinking of buying a gsi speedo. My problem is, either just a matter of just removing the old speedo and fitting the new one and it will work imediatley or there are some things that needed to be done? Thanks.
    Bzzzzz Admin Jack's Avatar
    Apr 2003
    Hicksville, GL
    44,173
    4 Post(s)
    Top one is a Mk2 speedo, bottom one is a Mk1 item (top one has mounting lugs on the top and side, bottom one doesn't).
    For ease of fitting, you ought to get the dialset to suit the car - so if yours is a Mk1, get some GTE dials (no lugs on top/side); if you have a Mk2, get GSi dials (with lugs on top/side).
    You CAN however fit Mk2 dials to a Mk1, and vice versa, but you'll need the loom connector block to suit the dials you're fitting - Mk1's have a 12 pin block and Mk2's have a 14 pin block.
    Mar 2005
    211
    Quote Originally Posted by Razorjack
    I think mine is a mk2 the car was manufactured in 1991 (still learning on the nova) http://www.pngclub.com/forum/viewfea...r.php?ref=2726
    Are these gte dails?
    Few weeks ago i had a rev counter installed on the pillar and i had to pass a wire from the coil i think it was the green wire not sure. I think i have to insall even the oil pressure gauge. The last picter is what im buying. I wish to know what i have to do for all of it to work. Thanks
    Club Member Club Member peester's Avatar
    Aug 2003
    staffordshire
    5,963
    oh.. in kph..? fair dos..
    they are late gte or gsi dials.. Think the GTE was called the GSi overseas.
    "let me drive.. i won't make a fool out of you"
    Mar 2005
    211
    But is it a matter of just removing the old speedo and puting the new ones or i need to add some wiring to the speedo?
